Boatguy2789
- Jun 24, 2025
- 9
Help? I’m working on a 1985 Mercruiser I/O with a A1G1 leg. I have a water supply issue, not enough water is making it around. Exhaust elbows are getting north of 220 degrees in about 10-15 minutes. Engine hits 180 and I shut it off. (On muffs, I have done the same test on water and same result)
I get a drip of water out of the main exhaust at the prop, but not a heavy flow around it from the relief ports. But I can tell water is circulating the lower unit because it I can see it coming out. And some water is making its way around the engine because I find it in the pump feed hose.
It is a raw water cooled engine with no heat exchanger.
I have checked:
Impeller - brand new (key is in it, lol) it spins freely with the shaft
Thermostat - brand new
Engine temp sender - brand new
Exhaust manifolds and elbows are completely clear of any debris
Oil cooler is free of any debris
I’ve also checked every water hose from bell hosing, lower unit, through transom, oil cooler, water circulation pump, thermostat housing, both top and bottom of exhaust manifold and elbow.
Nothing is in the lines stopping the flow.
I have not taken apart the water circulation pump on the engine.
Any other ideas?
I have checked:
Any other ideas?
