Boats from work.
redneck joe
Always wondered what you looked like....
I assume you are not giving a warranty on the work?
MikeSchinlaub
So, yesterday sucked. Turns out, I didn't put catalyst in my last cup of resin, and my last layer of mat was still wet. So I had to clean that mess up, and the other side started leaking water again. Supervisor helped me out on that one. He filled it with duraglas while I was cutting glass. So yesterday I glassed both sides, sanded them, and got it all ready to gel.
I brushed it today, and the guy picked it up around 2.
MikeSchinlaub
I finished the Skeeter yesterday and started on a Ranger. A good bit of damage on the bottom, with lots of water coming from the biggest one. Ground and glassed everything but that yesterday. Today was some more grinding, and packing the hole with duraglas to seal the water off before I glassed.
Also, the boss and supervisor took off to some races for the rest of the week, leaving me with the minimal authority that comes from bei g the most senior guy left.
Any bets on how long it takes me to go mad with power?
MikeSchinlaub
Finished buffing the Ranger today. I have a light tied to my cart, and it looked good with that, so I thought I was done earlier. Then I wiped it off with a microfiber and looked at it with a handheld light and saw buffing swirls everywhere, so I had to make that look better. I got the flake looking pretty nice, boss said don't worry about the bottom.
MikeSchinlaub
The ranger is done and in the wash bay. Next is a Basscat getting a hamby and a cheap fix to some damage at the back. Pic won't upload at the moment.
MikeSchinlaub
It's been a while. I've been waiting for the pictures to work again.
Here's the Basscat getting the Hamby.
Then I worked on a semi for about a week or so. I filled in all of the holes in the cab roof, gelled it, and the supervisor had to paint it because I can't reach the back without laying on it.
Yesterday I finished a Malibu that had the front fin broken off.
aspeck
That Peterbuilt is an interesting hull design! It doesn't seem like it would plane off very well, and doesn't look like a good displacement hull either ...
