Ayuh,....... Welcome Aboard,..... What's it doing, or not doing,..??My 1990 commander classic panel mount remote (shifter) has a jammed up throttle only buttonnot sure I can fix it? Having trouble finding a replacement that I can just hook up with the existing cables
I have it apart and sitting on the seat. Problem with the āthrottle only ball bearingā / spring. Trying to get a āplug & playā replacement isnāt going so wellAyuh,....... Welcome Aboard,..... What's it doing, or not doing,..??
Did you try hitting it with a spray lube,..??
Would a Uflex B183 work for you? It was plug and play with my Gen. 1.Wish I could get a new after market remote that would work with my āgeneration oneā cablesā¦ā¦ā¦![]()
Sounds like you're already 1.5 beers done!Button wouldnāt push in. Opened her up and spring / ball bearing fell out. Havenāt tried to reassemble yet![]()
Iāll see if I can find one onlineWould a Uflex B183 work for you? It was plug and play with my Gen. 1.
Itās the throttle-only plug thatās brokenButton wouldnāt push in. Opened her up and spring / ball bearing fell out. Havenāt tried to reassemble yet![]()
Found itIāll see if I can find one online
Are you asking me something here?Found it$250ā¦ā¦ no problem with yours
Yes, did that Uflex b183 work good for you?Are you asking me something here?
It was a piece of cake. You may see a reference to some extensions needed, but I did not need them. The cables just drop into position and are good to go. I did have to change the orientation of the front to the back, but that was very easy.Yes, did that Uflex b183 work good for you?
Easy install & adjustment?
