Mercruiser 496 gets warm again.
Butbro
I have a Mercruiser 496 2007 with closed cooling and it has only 150 hours.
It runs perfekt and get about 175-180 degrees when driving 25-30 knts.
If Igive more gas and drives 35-50 the alarm goes of and the temp rises to aprox 190-200.
Where to start, waterpump or mainfolds or what.?
Kenneth in Swede
have you checked the water passage for bravoitis?
have you pulled the end caps of the heat exchanger to check for debris?
