robertw007
- Jul 22, 2025
- 17
I recently acquired a 1969 whaler nauset and I'll be removing the gel coat to refinish the hull and deck.
I'll be using 2 coats of total boat epoxy resin on the original bare glass, followed by 2 coats of total boat barrier primer. hull and deck. Followed by 3 coats of wet edge, also hull and deck, due to color scheme I want for the hull. Whaler blue for entire hull, Kingston gray for interior, with some deck areas being whaler blue with a grip/texture material I already have.
For the hull I'll be adding some majik catalyst hardener in the final coat to give a nice strong finish.
My question is this.
Has anyone ever used resin to apply carbon fiber fabric to the keel to protect from beaching and such?
I really like the idea, but unsure exactly what layer to put it in. I think it'd be cool for it to be visible.
I do realize keel guard sells a $200 piece you can put on afterwards, but buying the carbon fiber is way cheaper and I'm already applying resin. Figured I could save a chunk doing it that way.
