Tilt / Trim Motor Torque Specs
meighkee
Just replaced the tilt/trim motor on a Yamaha 50, 2 stroke. Anyone know the torque specs to tighten it down evenly?
aspeck
Moved so you would have a better chance of getting an answer.
boscoe99
Torque is expressed in pound feet. Not foot pounds.
Many get it backwards.
Jeff J
I spent 20 years wrenching on military aircraft. Used a torque wrench on nearly everything and was taught the wrong terminology. Very hard habit to break but every bit as bad has confusing “then” with “than” or “break” with “brake” or “their” with “there”. At least the last 2 examples rhyme. Typos happen but most just don’t know and don’t care.
