happychapboater
- Jun 24, 2025
- 15
I’ve been having issues with one of my engines in that it is stalling at idle and sounds like it’s searching. I just got the tech mate device and have been comparing between my two motors. I noticed that the good engine’s temp while it’s cold now is at 70 degrees, while the other engines sensor is saying 85. I swapped sensors between engines and re-read the tech mate and the sensors showed the same readings.
Could this be that it’s a bad temp sensor and causing the stalling?
