1982 MR 180
redneck joe
I'll post a pic when I can but man o man o man steps installed on the trailer tongue to get in over the bow is sooooooo much nicer that trying a three point stance on the tongue, post and winch with wet feet.
Best boat dollars spent in quite some time. The way my body has degraded last 12 months or so i need to start thinking about this stuff more.
BWR1953
I think about this stuff every danged day! ;)
Got a link for the steps? Might need something like that in my future.
redneck joe
I went with the three step and I chose this one because the first step is below the tongue so that make the first or last step easy. I didn't have enough tongue space to mount there so we stabbed on some tube to the bow stop post. About 12 inches but I'll be cutting off about 5. And the wife likes it...
redneck joe
And don't hesitate. You will not be disappointed. One thing i did not take into account was my trolling motor mount. I knew i would have to mount on the side but didn't thing about the trolling motor being right there. I took the mount off and will put on the other side but I think your is permanently mounted. Unfortunately that leaves holes, which I had reused so don't feel too bad and since I'm into function more than looks I'm going to use my 6 inch non slip tape and a walkway on the bow to cover those holes.
So hopefully you have enough tongue space.
redneck joe
Just checked your thread you have motor mounted on opposite side so you should be good.
BWR1953
Thanks, I'll add it to the list of many things to check out for this boat. :sneaky:
redneck joe
Here is a pic. We misjudged the heigth of the peice we had to weld on (not enough room on the tongue) so the bottom step would not slide under the truck bumper so added a couple one inch tubes and longer bolts.
redneck joe
Either didn't see it or didn't come with it, a strainer for the new livewell pump so ordered on and wrong size of course so went looking thru my plumbing box (double sided tackle box) and had a bastardized set of fitting not sure what i was trying to use on but worked perfectly for this. Well 90% perfect needed a slathered or three of 4200 to glue in place.
Like me, ain't real prudy but it gets the job done...
redneck joe
So.... the trailer turns out was about 1.75 inch off center on the back rollers. Half inch on the front and decided the juice wasn't worth the squeeze.
Side note, the nuts were not as rusted as I thought. A couple shots over last week or so with liquid wrench and it was a one beer job at the ramp.
Then, there was this. I've been having to dunk way more than I want now i know why.
