wheel bearing seals
995jim
Hello, Is it possible or just not recommended to reuse a wheel bearing (back side of hub)seal in order to access the bearing on a boat trailer. Not sure if there is a tool that safely removes a seal without oblong Ing or deforming it
thanks jim
There are tricks to getting the seal out with the inner bearing.
It's about a 25% chance the seal can be reused
But for the $3 it is highly recommended to just replace
kenny nunez
Just a word of caution about grease seals. Always check that the inner lips of the seal fit tight over where they are seal the water out. And of course that they are the correct size for the hub.
Sometimes the seal surface on the axle shaft may have to be repaired with a Speedy Sleeve to covet rusting and pitting.
bwkre
Many seals are available in single or double lip. Cheaper bearing kits seem to often have single lip seals which may be ok for other trailer applications. A double lip seal will provide better protection in harsh environments. Best to spend a few bucks more and get double lip.
