Hi,
No luck.... :-( Once boat is just in the water, not even putting it in gear, it dies...
Thanks for the advice that was given for this issue.
1. Checked wiring => all OK
2. Installed new points
3. Set gap both on 0.16 (ref manual) but also tried 0.20
4. Checked the dwell with my scope and looks good
5. Checked timing => Set to 6
But issue stays the same:
Out of the water engine runs idle and high revs.
Once in the water the back pressure kills the engine after it runs for a few seconds.
Not sure if this helps: but I always run the engine before I leave for the water.
Once in the water it takes a few minutes before it dies. Then when I start it again it clearly dies way faster.
Any suggestions for the next step to diagnose? Thanks up front.
Regards,
PS: removed the carb (again...) and will double check everything.
