Here are some mock ups of the cast decks and transom fabrication i'm currently targeting. It's gotten easier to visualize this with everything gutted and taken apart. So far I have re-secured the stringers, most of the rivets had let go on them, I then added numerous aluminum cross members to tie into for the flooring, which has also added a great deal of rigidness to the decking structure with the strings and ribs all being tied together with these cross members. Lastly I've run PVC for different wiring lanes as well as the livewell, and leaving some room for drainage after I pour my foam.
From here I'll be doing a leak test to ensure I didn't screw anything up, and then I begin pouring in the foam. After that step I have to bite the bullet and buy a bunch of marine ply. it'll be expensive but I do have access to some better suppliers here rather than going with the menards stuff which I understand commonly has voids and isn't considered high quality.
Tap to view!
photos.app.goo.gl
Tap to view!
photos.app.goo.gl
Tap to view!
photos.app.goo.gl
