Jesse Walter
- Jul 11, 2011
- 39
I've have another couple threads involving my work on swapping a Bravo 3 drive onto my Bravo 1 boat. All and all that's a big success. I figured I'd start another thread with this issue because I've determined its unrelated to the swap.
The problem I've having now is an overheating issue. There seems to be plenty of flow with the ear muffs, doesn't overheat until I get the boat on plane.
At first I thought it was my raw water pump. Changed that, same results. Checked the thermostat and that looked a little suspect so I changed that, same results. Even tried a 2nd raw water pump with the same results. I've taken most of the hoses off and backwashed the system and everything seems to flow well. The 3 things I'd imagine that are left to check is 1. Exhaust manifold and risers. 2. Circulating pump. 3. Raw water hose at rear of engine. (Plastic fitting or bravoitis?)
I'm hoping its not #3 because access behind my engine is horrible. I also would hate to throw more parts at the engine (manifolds and risers) just to find out that its the plastic fitting or bravoitis. I'm about ready to drop the boat off at a marina to get looked at because I've just spent too much time on this issue...which seems simple but is turning out to be a headache and too time consuming.
Is there anything else I'm missing here or is there a way to troubleshoot this better than I'm doing?
