Hi,
Serial nr engine: 4506302.
The 165HP 6cyl in-line.
Based on the service manual and checking the upper unit of the stern-drive I have the "A-Mercruiser I-Drive Unit", some call it MC1 I think (the unit with the pin on the top of vertical shaft) it has no Pre-load.
I need to replace the main Oil-seal on the upper drive assembly.
On the forum and internet I read a lot about preload and the "special" washer. (with the NUT marking).
Now when I read the service manual nothing is mentioned about this for my unit. Just the end-torq of the nut. When I dissasembled it the nut was also firmly tight.
I see in later versions of sterndrive like R-MR-Aplha 1 they indeed speak about the pre-load in the service manual, but NOT on mine.
Could it be possible that for my sterndrive this was not yet applicable?
Regards, Yorick
Regards, Yorick
