I've got a 16ft Bass Tracker Pro 16. Console, 25hp Mercury. I'd like to improve hole shot and top speed a bit. The hull is ridiculously light. I've read it's like 300lbs but I've never weighed it.
Is it worth going to an SS? I've read that on lower HP motors it doesn't make much of a difference because they don't have the power to flex aluminum. Also, I'm not sure how much difference it makes that its a Jon and not a deep V.
Current top speed is about 19mph.
2) Current prop manufacturer, model, aluminum or stainless as a minimum.
*Not sure, but it's an aluminum.
3) Current prop diameter and pitch (required).
*10.5x13
4) Wide open throttle RPM and speed with an average load (very helpful)
* not sure, no tach. Average load is two adults about 200lbs plus fishing gear and 6 gallons of fuel.
5) Engine/drive make, model, year, and HP
Mercury outboard, Tracker, 1994, 25hp.
*10.5x13
