2003 Glastron VP 5.0 GL Overheat issue
New Amazon junk is just not of any quality. Stock GM marine pumps (what Volvo and Mercruiser use) is about $80
i_build
Here's that piece of garbage. Seller Anrain and it is no longer available. Take heed of the photo... chances are this snake is selling as another seller. 1756422640535.png
ESGWheel
Here are some of my go to places for VP OEM
  • Doug Russel Marine link
  • Leaders RPM link
  • Cecil Marine link > Cecil also sells Barr
  • Other places that folks have had positive success with is Marine Parts Express link
  • And of course, the OEM themselves: Volvo Penta Shop
And someone I and others have delt with re: RWPs is a nice gent on eBay that rebuilds them. Raw Pumps LLC link
i_build
Odd thing is that visually it looks ok was expecting to see pieces of the impeller. There are some small nicks at the end of the impeller and after disassembly of both the VP seems to have a gasket seal and the Amazon one uses an O-Ring... but oddly enough the amazon one looks like it should have produced something. Here are pics of both the VP bearing also would need to be replaced for reuse but the housing on the vp internally doesn't look to impressive. Sorry I wasn't aware that we shouldn't name bad vendors will not do that again.Amazon Pump.jpgVP Pump1.jpgVP Pump2.jpg
Lou C
I have bought OMC parts from this vendor on Amazon, that's about the only one I'd trust, and only when I can't get it locally.
I have a local marine shop I go to and he can order OEM Merc, OMC or Volvo parts plus he can get me Barr exhaust, Deka batteries, etc. And because I go there a lot he gives me a discount! It's good to patronize local shops because they can be helpful in other ways, they will know good fiberglass guys, painters, upholstery guys, etc for stuff you can't do yourself.
