which caulking is acceptable
995jim
Hi. when I go to reinstall screws to attach a bracket on the outter face of my transom on my fiberglass boat which of these caulking choices is best to leak seal
butyl
rtv silicone
marine silicone
thanks jim
dingbat
butyl
rtv silicone
marine silicone
thanks jim
3M 4200FC
Boat caulk by life caulk
Never sillycone. Butyl is for windshields, hatches and RV roofs
FYI, look up the practical sailor caulk test results. The 3M products failed in their teating
Pmt133
I like boat life and their life caulk and seal. I recently bought a few tubes of the caulk. I had one that wouldn't adhear worth a ****. Peeled off like painters tape. The other tubes (which I then had to test because of the first one) was fine. First time I ever had an issue like that. It was an older lot number but still within usable range so just check that before you commit.
Are these through hull or blind holes?
nola mike
I've been using PL Marine sealant, I like it better than 4200. Just one opinion though
