This trailer has rocking bunks
guy48065
The trailer that came with my used (2000) bowrider has bunk boards that pivot on their brackets. They used nylok nuts so this might be intentional--tho I've never seen this. Everything else about the trailer is ship-shape.
Should I tighten them with the boat loaded, or leave them to self-adjust?
No rollers on this trailer--just the bunks.
Cortes100
Sounds normal.........the last 3 boats I've owned came from the factory with a shoreland'r trailer......and all had the bunks that pivot. Just check the bolts and tighten just enough so the bunk still moves but the bolt isn't flopping around
guy48065
Before I posted I asked AI.
Answer it gave was pretty much along that lines of "that is wrong, it will damage your boat, will wear out the hardware".
dingbat
Didn’t say what make of trailer.
I have a Loadrite Aluminum trailer with AB (rocking) bunks.
Allows the bunks to pivot for increased contact, so the hull sits flat on the bunk
dingbat
I've never seen that. What would the advantage be over fixed?
The hull sits flat on the bunk increasing the surface area over which the weight is distributed
More contact area equals less pressure (per unit weight) exhorted on the hull
redneck joe
But would not bunks secured with boat on the bunk be ok? Is there something to keep the bunk from flopping over too far? That has happened to me.
dingbat
In most cases, yes.
In my case, the builder recommends the hull being supported directly under the stringers at the chines. As such, two piece, self adjusting bunks made sense. Far easier than messing around cutting angles on a one piece bunk.
The rest test..........how much work to keep the pivots operational in SW
redneck joe
Location i get but don't see how a pivoting system does anything more. Just put them where you want them and at a loaded state lock them into position. Not saying is a bad thing just over thought and over engineered imo
Lou C
I think Load Rite called these Self Adjusting bunks (SA bunk trailer) I can see how they would be advantageous because it allows the boat to load easier and launch easier because it compensates for the angle of the ramp....like a roller trailer with pivoting roller bars but without the extra cost and complexity of rollers....
airshot
The pivoting bunks should have a stop to keep them from pivoting to far, as least all of the ones I have seen do. As the boat loads and unloads the hull shape changes as it goes over the bunks. In some cases, the sharper edge of the bunk can carry a lot of weight for a few minutes and over time can cause some damage or wear. The pivoting bunks should not be floppy free, they need to be lightly snug so the hold position when not supporting the boat. Part of trailer maintenance is checking these after unloading your boat. Allowing the bunk to pivot and maintain full contact on the bunk lessens any chance of excess wear or damage to the hull. Like everything else on a boat trailer, maintenance is needed regularly to keep it working properly.
guy48065
I think I'll snug up the bolts so they don't move "freely", but will adjust under the boat's weight.
EDIT:
Can't. The bunk brackets must have bushings in there. The bolts are "ugga" tight and the bunks move freely.
I guess AI is wrong again. This is designed to move like this.
guy48065
Uhhh...is Escort a trailer maker?
The winch tower has an Escort Trailers sticker on it & the name is familiar. Seller may have told me it's an Escort trailer.
