cyclops222
- Mar 21, 2024
- 3,101
I called American Tire near me. He said they have the Honda units. Waahoo
That's for your car...won't do a thing for a trailer.I called American Tire near me. He said they have the Honda units. Waahoo
TST 507 with screw on sensors is what I use for my boat trailer.Did a web search. 2018 Accords use the RPM speed of each wheel as a way to sense which wheel is not spinning correctly. Need to buy a ...Stand alone setup.
Thank you.![]()
i use my left foot.If air pressure is that concerning, why not fix any leaks. I check my tires frequently and end up adding air only after long winter storage. During summer boat season tires always within a few lbs. In my wife's Honda, the sensors are always acting up, have had batteries replaced and sensors rebuilt a couple times, finally just gave up. Just looking at the tire tells me whether it needs air or not, sensors are useless. My Jeep sensors work very well, but they still read different depending on temps and weather.
Before I had TPMS, I picked up a nail. I had no idea the nail was in there and letting the air leak out until the tire was on the verge of shredding itself. That is the value of TPMS whether it be on your car or trailer.If air pressure is that concerning, why not fix any leaks. I check my tires frequently and end up adding air only after long winter storage. During summer boat season tires always within a few lbs. In my wife's Honda, the sensors are always acting up, have had batteries replaced and sensors rebuilt a couple times, finally just gave up. Just looking at the tire tells me whether it needs air or not, sensors are useless. My Jeep sensors work very well, but they still read different depending on temps and weather.
That is why I look at my trailer tires before and after each trip. Not hard to notice when a tire is getting low. Sudden blow outs from punctures won't let the sensor show it. Don't get me wrong, the sensors are great tools, but I can count on one finger the number of times they actually showed me a problem in the past 15-20 years. But, I have had to have them rebuilt a few times from giving false readings.Before I had TPMS, I picked up a nail. I had no idea the nail was in there and letting the air leak out until the tire was on the verge of shredding itself. That is the value of TPMS whether it be on your car or trailer.
What happens when you pick up a nail on the trip? That is where they are most useful.That is why I look at my trailer tires before and after each trip. Not hard to notice when a tire is getting low. Sudden blow outs from punctures won't let the sensor show it. Don't get me wrong, the sensors are great tools, but I can count on one finger the number of times they actually showed me a problem in the past 15-20 years. But, I have had to have them rebuilt a few times from giving false readings.
