M9540 24 speed parking brake
alldodge
Think I just want to vent
Hauled tractor to a tire store for a new set of tires. Hauled it out, guy pointed to where I could park it which was on a slight hill. Stopped and took out of gear, engaged parking pin lever, and left.
Picked up tractor, loaded, stopped tractor, took out of gear, engaged parking pin lever. Chained it up and drove home.
Get home, unload and try to attach batwing and tractor will not stay when I engage parking pin lever. Get off tractor and verify lever is moving cable and pin should be engaging, but I can roll it. Appears something in the trans broke.
Reading online this is an expensive repair. Called the tire store and he said he had to put a block against the wheel to keep it from rolling. Says he knows how to drive a tractor, the issue does he know how to drive mine? I'm guessing he put trans in 1 (was in low range) let the clutch out without disengaging the parking lever.
So guess I'm going to drain and remove the side cover to see if it's just the paw or I need a $10K plus repair because I wanted a new set of tires
aspeck
Deep breaths until you see what happened.
Mc Tool
Master Chief Petty Officer
insurance ? accidental damage
Just finished some commiserative beers with neibour , he been here half a day trying to pull out a stump for me .... used both of his tractors and only gave up when it split one of the bucket cylinder rams down the side
FLATHEAD
Bad news either way. Incompetence in the workplace seems to becoming the norm.
alldodge
Talked to 2 dealers and I'll be taking the tractor the second one. First one never did one and was having a hard time figuring it out. Gave him my phone number and said he would call/text. No response in 3 days
Next dealer is an older guy and went straight into what it will take because he's done them before. Says it's time consuming but not that hard. Told me the guy that broke the paw (says it's like a sheeps foot wrench) most likely he didn't even know he did it. Says if the tractor is moving even real slow and the parking lever is moved into Park, it snaps the teeth off the paw, has to be completely stopped. Says it will be about $3700 but would need to re-figure when he has time. Said call him in a month
Least it's not 10K
Mc Tool
Do you have to have it ? like if I got told the parking pawl on my car was broken ( surprised its not :)) and it was going to cost thousands Id just start using the handbrake . The only person to use the handbrake in my car is the guy who does the annual roadworthy test ....he is also the only person who uses the rear seatbelts.
alldodge
The tractor uses a hydraulic actuated transmission with shuttle shift. This means that there is nothing other than the parking paw to keep it from rolling when turned off. It does not have a cable operated brake system, so leaving it even in gear does nothing, it will still roll
Some have cut a 2x4 to length and place it between seat and brake pedals, but I'm not going to try that
Mc Tool
Yeah it seems wrong from a "dont mis-treat your tractor " point of view , but after a bit of thought I cant really think why not .
I guess there are times when its ok to use something for a purpose it wasnt intended for ( like battery drills on your fishing reel ) with reasonable success
alldodge
If I need to use it before I can get it repaired I'll take something with, otherwise it will sit in the barn until it goes to dealer
alldodge
Guys I know what wheel chocks are, my 2x4 comment was
Brake pedals inside the cab to seat which will keep the brakes applied
wheel chocks are dumb and work
my issue with a bit of 2x4 between the seat and the pedal is the seat foam deforms a bit, the 2x4 slips and then the tractor is rolling down a hill and running over some hipster on a seqway.
at least spend $40 at Bezos's super mall to get one of these brake pedal depressors. https://www.amazon.com/RAMATA-Steering-Depressor-Accelerator-Maintenance/dp/B0D93LY56W?th=1
or hit the local NAPA for one like this. https://www.lislecorp.com/specialty-tools/truck-pedal-depressor
or this. https://www.hunter.com/shop-hunter/consumables-accessories/accessory-details/?code=WA15-S
or this. https://www.walmart.com/ip/OEMTOOLS...s-Maintenance-Clutch-Specialty-Auto/500992440
goes between the steering wheel and the brake pedal. less chance to slip off the steering wheel
dingbat
Surprised you don’t have a ratcheting brake lock on the brake pedal like my New Holland.
Certainly not on par with a parking brake, but works well enough if I don’t have the bucket on to use as a brake
alldodge
Knock Knock, anyone home
Mc Tool
Are you sure about that 🤣
Hey @alldodge , you stated you were not going to try that, I simply made suggestions to pedal depressors in lieu of a chunk of wood.
