Lou C
- Nov 10, 2002
- 13,706
I was responding to someone who posted up on the hull truth about water in cyls on a Merc 5.0, the owner found that his intake was leaking apparently from a fitting that has a copper tube that connects the intake to the exhaust elbow. Leaking from the inside of the intake, into the cyls on that side. What is the purpose of this tube, is it to circulate hot water under the carb base, or is it exhaust gas?
I was guessing it was water routed from the area under the 'stat housing, to under the carb base, then up that tube and out the exhaust, but what do I know lol?!
Never saw this before.....
www.thehulltruth.com
