Boats from work.
FLATHEAD
Post 146 Pic shows the screws can be gotten to easy enough, what am I missing?
So just use a standard screw drive with a long shank
Phillips
I think what he is talking about is the upper screw has no depth for the screwdriver tip to go deep enough to get a bite?? Not sure.
If that’s the case I’d grind the tip down till it fits.
alldodge
Ok thanks
That screw wasn't installed after the head light bracket was put together, the head light needs to be removed to get to it.
MikeSchinlaub
Ok thanks
Probably the red ones. It was a single bracket for both lights, attached to the panel by the 4 blue marked bolts. I would have to have it in my hands to be sure about the reds.
Anyway, I got it out, so it's not a problem until I put it back.
MikeSchinlaub
Got the camper sprayed today. A bit over 12hrs in today.
This corner looked better before I sprayed it. :mad:
Supervisor had to get up there and spray the tall guy stuff.
MikeSchinlaub
Guess who gets to touch up the camper now. First the boss whacked it with the drill, but only a little spot, then when I was closing the lower part it hit on the upper panel. Didn't think to check alignment as it was being closed, we just lined it up with the panels on the side of the windshield and left it. Uuuuggggghhhhhh...
