Hello all. Can anyone share some thoughts please as yall have more experiance than I. I came across this and have a simular situation. Problem started with fuel starvation under load with my 5,7 volvo penta. Approched it by installing new fuel pump. Started ran on trailer great. 5 times at the ramp and she died under load. after two pumps I moved on to replacing cap rotor plugs and wires as it was due. Now it will not start at all. sputters after sitting and cold then will not start, fuel in the oil. Changed the oil. Man the guys at auto parts store got mad as hell when I pumped the gassy oil in ther tank! I didnt know better,,,, Where is the best way to depose of the gassy oil? Anyway.. Pressure at the rail is 55 and holds. (meaning no open injectors?) I changed the fuel regulator then changed it back to original after cleaning it. No differance. Any thought or suggestions? Thanks
