Merc 250 Verado Fuel increase
alldodge
The starboard motor has the higher psi and FMS was replaced more than a year ago. Starboard is doing fine other than the low voltage alarm which is another issue
Both cowls have paint along with stern of boat. Will take more pics but on my way to sisters in KC MO, will ne back late Tuesday
alldodge
I'm at my sister's in KC until late Tuesday, appreciate communication and will respond after that
muc
"Retired" Association of Marine Technicians...
Something that popped into my head, it doesn't fit with the vibration you experienced. But might be something that could effect the unequal fuel burn.
Your engines have software called ARO --- advanced range optimization.
This will adjust fuel and spark when certain parameters are meet.
When this is operational it won't be felt by the operator or show on the Smart Craft screen, It's only visible with a scan tool.
Next time your at your boat, maybe connect the Tech Mate and look for something along the lines of "lean burn control state".
Maybe one engine is going into ARO and the other isn't?
alldodge
Well I messed up a bit, searching for NGK LKAR7C-9 which is part number 93961 I would up with LKAR7C-8 and doesn't list NGK
Looking at plugs it list -9 has 9mm gap (0.035) and -8 has 8mm Gap (0.031)
Going to contact amazon and get a refund
alldodge
Yes test equipment like meters and gauges need to be double checked every once and a while.
Suggest you hook up shore power overnight and check float voltage on the batts. Note you will need to check this before you use any electricity on the boat.
Looked at Odyssey warranty and they state the float must be between 13.5V to 13.8V otherwise damage can happen and warranty is void. Well I'm wondering how accurate my meters are and if it must be that accurate maybe I need to reconsider my standard go to Battery?
muc
Might check the battery in your meter, my cheaper meters tend to start drifting off when the batt starts getting lower -- my high buck meter is rock solid until the lo batt pops up in the display.
Have you looked at your charger? Back when I worked for a Chap dealer they came with low cost chargers but they still were batt type selectable. But almost all of the boats I worked on were 3 bank chargers. You should have got a big folder with the new boat, charger manual should be in there. If not google the charger model and see if it's online.
alldodge
It's a 3 bank charger and have read the manual. I to switch to AGM setting after bring it home but with two Merc AGM and Interstate LA it would not switch. Also finding out the Merc AGM isn't a true AGM.
After installing the 3 Odyssey Bats, it switched right over. Will try to find the manual or get it from the unit
alldodge
Charger is a ProSport HD20 Plus
All the voltage readings kept changing slightly. The Craftsman 82344 meter always read 0.1 to 0.2V lower than the Klein CL390.
Klien
Float 13.6 Bat1, 13.4 Bat2 and 3
Unplug 13.1 Bat1, 13.0 Bat2 and 3
Start motors and there was no 2 beep warning
Motors off Bats are 12.9 all around, but figure give it more time and 2 of them will go down a bit lower
Motor running Simrad shows 14.0 to 14.1 on first start. Second start it shows 13.9 for a while. Reved motor up and it did come up but never saw 14.5V
Didn't take my Techmate down, will go back later
alldodge
A dock friend said they saw someone today taking pics of my boat on the lift, of the bow area. Didn't stay on dock long so don't know if they took other pics of the motors and the paint.
alldodge
Didn't see ARO or similar, did find closed loop and both were using that at idle. Started motors twice and never got the low Bat beeps
Pulled plugs and reinstalled waiting for new to come in
alldodge
Replaced the plugs and didn't notice any vibrations but also didn't take it out
Called dealer and they agreed to take care of the overspray but I have to take it to them. I said thanks for admitting they caused it, but no thanks. Dealers is 1.5 hours away and who knows how long they will have it, then there is 2 round trips. Figuring it shouldn't cost more than $200 to get a local guy to do it, I'll just pay for it
MarineSp
Following along on this one. Interesting that both motors are reading similar fuel pressure now (SB 42/49, Port similar). The spec range for the 250 Verado is 42-44 psi at idle and 49-54 key ON — so your actually right at the bottom end on both which makes me wonder if the issue is upstream of the engines. Maybe fuel supply from the tank cant keep up when both are running hard, especially if theres any restriction in the pickup tube or antisiphon valve.
The yellowish fuel in that container is worth paying attention to. Even "no-ethanol" fuel from marinas can go stale if it sat over winter — the lighter fractions evaporate first and whats left burns less effeciently. Might explain the higher fuel consumption without any codes showing up. Fresh fuel and new filters could make a bigger diffrence than expected.
Also curious — when the SB was using 2.0 gph more and vibrating, was it always at the same RPM range or did it get worse as RPMs went up? If it was worst at lower RPMs and smoothed out up top, thats often a partially fouled plug or injector rather then a fuel pressure issue.
