Busbar addition.
jt1313
Hi all. Im interested in wiring a positive busbar to a perko switches com post. My question is, does there still need to be a fuse between the com and the busbar as the switch (the boats master switch) is already protected. And what size fuse/breaker would be needed if so. Thanks
alldodge
No, it's just good practice
If your running a smaller wire in addition to Bat cable than even better reason for a fuse/breaker
dingbat
What are you installing that you need 2/0 connected to a busbar?
