icatchfish
- May 20, 2026
- 20
Howdy,
As the title says.
Story:
Motor hits a wall on revs under load. Did up both carbs with new needles, floats, and gaskets. Cleaned up all jets. Carbs were actually fine after getting into them but replaced and cleaned stuff anyway.
Motor fires right up. Screams to life and happy days. Tune up on the water, making progress and then engine dies at the dock. Ended up being the neutral safety switch for the hydro electric shift was dirty (engine side). Cleaned it up, cranks over as intended. Won't start worth a darn.
Got her to come to life eventually, cleaned the sparkys up and bang she fires right up. Trying to now tune up in the driveway as she's a smidgen rough at idle and will die if I let it.
Now, she's a crank no start.
Fresh fuel, checked black and yellow kill switch wire, even sprayed a little cheater fluid to see. Holds prime, set my carb screw settings back to where they *should* be. Just a crank no start.
I have fuel, air, spark. No bang on the suck squeeze bang blow part though.
Any advice would be appreciated.
As the title says.
Story:
