HerrGruyere
- Sep 1, 2025
- 6
Hi!
I have a ‘77 Johnson 70hp (70el77s). She’s sat for 20 years. Last year with a crap battery, I got a couple of weak turns when engaging the starter. This weekend, I got a new battery and nothing happened when turning the key. Some things to note:
Cleaned all connectors to super shiny (terminals from battery to solenoid, battery to ground, solenoid to starter, etc.).
Choke engages when pushing key.
I get 12V at the solenoid from the battery.
I get 0V when key is turned to start. I may have measured wrong, though. I put the pos lead on terminal to battery and negative lead on solenoid to starter.
No clicks or hums from solenoid.
Taking the lead from battery and touching to starter lug does nothing but spark.
Cracked open the remote control and didn’t find a neutral safety switch. No wiring is on the motor that I can see near the gear levers.
Sprayed connections with WD-40.
My guess here is bad starter and solenoid and possibly a bad ignition switch. Just checking with the experts to make sure I’m on the right track. Please let me know if I’m missing something. I’ve scoured the Internet but getting mixed results.
Thank you!!
Thank you!!
