‘83 Chrysler 7.5 No spark
Xcakes0X
So I’ve been working on an ‘83 7.5 Chrysler with no spark on either cylinder. I went ahead and replaced the stator, trigger, and the cdi/ignition coil. I’ve checked all grounds and disconnected the kill wires to avoid the kill switch. Even after all this I still have no spark any ideas as to what else could be causing this because I’m running out of ideas?
Nordin
Which stator did you change, the stator CD F525301 or stator alternator F525095 ?
Nordin
Okey, now you have to measure the output voltage from the stator and the trigger.
Output from the stator usually should be 180 VDC or more and the trigger voltage 0,5 VDC or more.
Sounds odd you do not have spark despite changing both CDI, stator and trigger.
How is the magnets in the flywheel? Use a screw driver and check how strong the magnets are.
