01 mercruiser tilt problem
Mban2460
Im new to the boat owning so bare with me i have a 2001 sylvan180 with a 4.3l mercruiser with the alpha on drive. My tilt will not go up. I have replaced the trim pump motor and the selonoids for both up and down. Still no up is it wires or is there another part i dont know about. thanks in advance
Chris1956
That motor probably has a trim limit switch. They were made of copper, were located in the outdrive tilt pivot, and were exposed to the water. A lot of them rotted out. If they rot out or otherwise break (common), the motor will not trim up.
Try using the "trailer" button. If the trim moves up, either use that to trim and tilt or fix the trim limit switch. If it were me I would just use the trailer button, or jumper the trim harness to allow the trim up switch to function w/o the trim limit switch.
CaptainMak
Try playing around with the trim limit and sender on the sterndrive. They look like hockey pucks with 2 screws holding them on to the Alpha drive.
It could be one of them is shorting out. Just loosen the screws a bit and move the limit sensor around. Also, does the pump make the whining noise when you press UP ? Do the solenoids click when you press UP ?
Bt Doctur
If the trailer function works ,then the trim limit switch or its wiring went bad. Shame you spent all that money
j2ky2k
Don't forget to check fluid level, easy to not think about being new to boating, Good luck!
