40 hp two cycle, two cylinder, power tilt/trim,oil injection, console steering. Runs ROUGH---skips, jumps, etc.... Will barely idle, but I know its not flooding out, or at least we don't think it is. The plugs are getting fire, reputable mechanic has replaced stator, trigger, and CDM packs with no luck. We noticed a threaded hole right beside the fuel mixture screw on the carburetor that goes completely down into the bowl, mechanic said it was a vent hole that is supposed to be there but I'm not so sure. At first we diagnosed it as an ignition problem, but since replacing all of those parts with no luck we don't know where to turn. Carbs are clean. Any help/ideas???
