Not off to a good start. Boat went in the water and whenever it went from idle to fwd/rev it would stall, unless I gave it a lot of throttle - emptied what little fuel there was and filled up with a new tank, ran 60 minutes to home port behaving the same way.<br />Now, it won't even warm up. Runs for about 45-60 seconds, regardless of how high it's throttled, and quits. I can restart it right away, but it will die again.<br />I've replaced all the plugs, the distributor cap(it was worn), rotor, checked the batteries, put a new water separating fuel filter in, jumped out the oil pres. switch, but no change.<br /><br />FWIW, the entire lower unit was replaced last year because we hit an unmarked submerged object. Boy, those stainless steel props sure do transmit all that energy right into the lower unit gears....<br /><br />Anyway, HELP! I've been waiting all winter to go boating!<br /><br />Thanks
