I have an 03 Yam 50 on 19' carolina<br /> skiff bought new and have had fuel problems since. every time I throttle up from idle it begins to die, unless the fuel bulb is being squeezed at the same time. I have replaced all the fuel lines and fittings, fuel pump was replaced and the carbs were <br />removed and cleaned by the dealer. virtually everything is new in the fuel system. The motor has been run with the gas tank cap on and off,<br />filter in and out the pick up screens<br />in the tank off and on and still no solution.<br />I was hoping someone else has had experience with this, at this point I'm lost. appreciate any help
