I'm not overly familiar with outboards, my fathers 3.5 stopped circulating water, none at all coming out the pee hole.
Got it apart, the impeller looks good.
I spit on the pee hole and blew air through the intake above the pump housing with a straw and it made one little bubble. Didn't seem like it was steady air coming out.
There is rust on the drive shaft. Is it possible the water is getting pumped up the drive shaft, causing the rust, instead of up the intake hose, a bad seal or something?
Thanks
Thanks
