alandchris
- Dec 25, 2007
- 106
Gents
I'm at a loss for the moment. I have an 04 Merc 9.9 standard longshaft - remote steer/ electric start. I just picked it up from a local guy. He started it but now on my boat I cannot get it started. I don't have a clue as to how the factory (Tracker 2001 Pro Angler V16) wired it up for electric start.
I know that both batteries are fully charged (tested them) - and both are brand new. All the accessories work - just can't start the motor. I don't know how to test the ignition switch to see if that is the cause of the problem.
Is it true that the battery cable from the starting battery goes directly to the ignition switch - but positive and negative sides ? Or does it go into the controls and then to the ignition switch? I thought that when you have the battery cable connected to the battery - you should be able to take a tester to the ignition switch and put the black/neg on the ignition terminal with the solid black wires and then the red/pos on the terminal with the solid red wire, turn the ignition on - and the tester goes on ? Am I wrong ? I then left the black/neg on the black wire terminal and move the red tester side - touching all terminals with the igntion off, and then tested all with ignition on - no succesful test. What am I doing wrong. I have an 8 pin plug from the engine - and it was hooked up.
One thing to note - the 8 pin harness on the motor only has 7 "female" ends - could the 1 missing one be the culprit ? If I recall correctly the guy who I bought the motor from hooked up the motor inside the cowl to the battery with jumpers even with his boat / and this motors 8 pin connector plugged in.
As a PS to this - I have new controls totally separate from the boat and does not have anything to do with the above info - but it has an 8 pin connector and then also another connector that has a plug on it with 4 wires - a black, purple, grey and brown wire. Can anyone tell me what these wires mean - do they hook up to the battery via a battery cable - which wire does what
Thx for any help before I go to the marina for them to fix.
Al
Al
