I need a little help to get started. I currently have the Volvo/Penta 4.3GL with the SX drive, labeled with a 1.66 gear ratio. It now has a Volvo brand stainless prop marked as 14.25 x 23 but my max indicated rpm is 4900. I really don't believe the 4.3 could spin the 23 pitch that high. Possibly the installed prop was re-pitched, but since I'm the third owner I don't know the history, so I don't have a reliable baseline. I'd like to get a "really good" stainless replacement but honestly don't know where to start. Unfortunately, I don't have a place that will let me test various props, so I need to pick the right one first time. I know the stepped hull on the Regal boats is a little faster than most and doesn't seem to fit well with the normal calculated prop selectors. The engine is stock with only some cold air ducting. My priority is to max my top speed without totally killing the holeshot and keep it at the spec'd 4600 max rpm. Does somebody have any real experience with a stepped hull Regal 1800 and a carburated 4.3GL that could help?
gozfast Posts: 1 Joined: Thu Sep 04, 2014 8:53 am
