montanabay
- Nov 14, 2009
- 17
Hi All,
I was reading some test boat stats on the Suzuki 115 and noticed that similar weight boats were getting up to 42mph @ 6000rpms with the stock stainless steel prop(SS 3blade, 14/22)
http://www.suzukimarine.com/boat_bu...ina_skiff/sea_chaser_1800_roll_gunwale/df115/.
When I run my Western Eagle Skiff 18' (similar specs to Sea Chaser 1800 Roll Gunwale) I usually top out at 5500rpms and 33mph (2 guys, 1/2tank, light gear), which makes we wonder if I'm running lean or not getting enough gas to the engine? Its not a huge deal, since running the boat @ 4500 is the most fuel efficient and comfortable ride, but that last few dead calm days when I could run flat out...well I didn't seem to run flat out. How does your boat perform with the Suzuki 115?
Also, I have a powerlift and have played with the prop depth and trim, same top-out.
Looking at my fuel line to my large RANCO, it looks to be 1/4" line, but the motor is rated to 3/8", enough difference? What does are symptoms of an engine not getting enough gas at higher rpms?
Cheers,
Josh
Cheers,
Josh
