'05 Tohastu 9.8hp Center Section/Tube Replacement
captmick39
Just bought above, runs great...1 small problem;
Seller hit a rock about the size (his words) of a 400 big block.
Cracked the center section/tube in half. Then it got welded (sorry excuse for a real welding job), then Brackets added between lower unit & powerhead, then JB WELD...You get the idea, a Mess. Royal mess at that.
I'd like to start from scratch w/another center section/tube, however a new one is pricey, too pricey from what I've seen online.
Is there a 'place' out there online where I can acquire this part, used, in good condition?
Thanks,
-Mick
pvanv
Re: '05 Tohastu 9.8hp Center Section/Tube Replacement
Year does not matter. Model/serial is everything. Also need to know shaft length. If you have a 9.8A2 short, you need 3V1S610200 DRIVE SHAFT HOUSING S $165.67. You will also need 3V1013030M GASKET, ENGINE BASE $18.40. Not many used ones laying around.
