Hello everyone !
Recently got an 1998 25hp 3 cylinder J25RMECA and i think I'm having spark issues
in the service manual says that the coil P/N 584826 primary resistance should be 0.28 +- 0.05 ohm and secondary resistance my meter should show 2300 +-300 ohm.
the engine came with P/N 056323 (since P/N 584826 was replaces P/N 056323) and each coil shows primary resistance at 0.9 ohm and secondary at 253 ohm.
Ive look everywhere for 0586323 coil specifications but can cant find it anywhere .
My question for you good people at Iiboats.net is should 056323 coil read same values as 584826 coil from my service manual? or what the 0586323 coil reading should be ?
Any help will be appreciated !!!
Thank you .
Thank you .
