06 Suzuki 40 hp outboard tempeture warning buzzer
Donjoe1043
my 40 hp Suzuki pumps water like crazy but the temp warning light and buzzer keeps going off. Has new thermostat . Doesn't seem to be hot but once the warning comes on it will only run at idel speed. .???
Donjoe1043
What is the problem with my 2006 Suzuki 40 hp temp warning going off
Donjoe1043
2006 Suzuki outboard temp warning going off
GA_Boater
Donjoe1043
One thread is enough, 3 threads is over the top.
Moved into the Suzuki section where it belongs. Wait for some responses.
99yam40
yea, sometimes I have to hit the refresh button to see if it took or not.
I think Suzuki has a water level switch along with over temp switch.
might check to make sure they are functioning properly.
might even check the motor temp with a infared gun to see it it really is overheating.
if it is a water pump may be needed or cleaning out the water passages
