07 50 ELPTO Raw Water Pump Impeller
James D. Evans
Serial Number 1B488368.
trying to find a impeller kit.
Ive pulled the lower unit, it has a metal upper housing. Best I can tell Water Pump Impeller - Sierra - iboats seems to be the impeller I need. But I can not find the gaskets for the pump housing. Should I just put a new impeller in and call it a day?
Fun Times
Re: 07 50 ELPTO Raw Water Pump Impeller
Hi there James, The OEM Mercury part number kit your looking for is 821354A2 Repair Kit, Water Pump.
In looking around, it seems Sierra marine does not offer a kit, only an impeller by itself like the one you found here at iboats. And yes, that impeller is the correct one for your engine model.
The only aftermarket Kit that is available is made by GLM ( AKA Good Luck Marine):D Part number 12045 GLM which to my surprise is not offered by iboats.:confused:
