dsbunton646
- Apr 25, 2011
- 3
Toward the end of last season it started this sputtering/missing as fuel/throttle was applied. It is always on the initial use for the day. It will run kind of crappy for a short while and then eventually clear up and run perfectly. At first I thought I got some bad fuel in it. But after some seafoam, new fuel, and changing the spin on fuel/water filter the problems persisted....but always at first use of the day or trip. I've since changed the distributor cap, rotor, plugs and wires, as well as the spin on filter again. This time I poured the filter contents into a glass jar amd inspected it for water or contamination. The fuel from the filter seemed fine. I took it out yesterday after all that and fresh service and it still did the exact same thing but seems a little worse after having sat offseason.. After about 30 minutes it came back and ran fine. No stumbling anywhere in the throttle range. Maxed out WOT right where it should have after a little use. No stumbling when getting on plane etc...
Is there another filter I'm missing? Or any suggestions for me to try? I haven't checked fuel pressure butI suppose that's the next step?? Boat has about 160 hrs on it total.
