I have an 08 DF 90 that I am having some issues with shifting.
I was starting my motor maintenance this weekend and figured I would start with the oil. So I hooked up the muffs and started her up to get her warm for the oil change. As the motor was running in neutral I noticed the prop was spinning. I could easily stop it with my hand but as soon as I let go it continued to spin. I hopped in the boat thinking it wasn't in neutral all the but it was. I kicked her up in gear and it made a grinding noise that did not sound good. It did the same thing when dropping it in to reverse. Not sure if it something that it is just doing it cause it was on the muffs or not but please help. Do I need to adjust the shift linkage and if so how do I do it?
