'08 tahoe Q4SS 3.0L mercruiser 135HP
kingkoyl
I purchased this boat new, and since new, the engine runs on for a couple of seconds after i shut it off. It also idles rough and sometimes stalls. I've had to raise the idle ever so slightly to start it hot or else it takes a few tries and even then, sometimes it stalls again. Upon hard accelleration, it boggs for a second then begins to accellerate.
Can anyone give me some ideas where to start?
Zeeter
Re: '08 tahoe Q4SS 3.0L mercruiser 135HP
Take it back. That should not be your problem.
kingkoyl
lol.................i appreciate that but unfortunately it's a little too late, warranty is up and i've seen the work my local boat center does and i'll never take it there again.
Fun Times
Hi, Well for starters the timing could be out of adjustment, or the idle could be set to high, Could be bad gas, Water ect. Check your fuel by pulling the filter and look and smell it to see if it's bad, If not, Then the idle is/was set wrong from new And the dealer may have set it wrong;) at new boat prep time and that should be covered because you have all ready paid for that while buying the boat from new It's in the deal of buying the boat and they call it prep and delivery, And you pay for that up front. Also if you have the new turn key start engine then and it is running like that then some times the only fix is a new carb needs to be installed.
kingkoyl
Thanks Boat Teck, should i be looking at the ignition timing as well ? and if so, would you know what the timing should be for '08 4cyl( 135HP)
THANKS A BUNCH
Cheers
Fun Times
THANKS A BUNCH
Cheers
There might be a sticker on top of the flame arrester that would tell you what the spec's should be set for. Keep in mind to set the timing you will need to ground out a certin wire to check and adjust the timing. you should get your idle adjusted to spec's first, Because most of the time the 4cy engines are harder to set the idle just right then V6/8 engines because to get it just right you normal have to play with and adjust the throttle cable to get the engine to idle down smooth every time after moving the throttle. It takes some time to get it just right or you could have different idle speeds at times.
Tom Mac
I have a new 2010 Q4SS, 3.0 and I just let it idle a few seconds before shut down. Not the answer you want but I dont have a problem if I do this.
