Re: 1.2 Gamefisher repair manual and/or float adjustment
There's a little metal tab that moves the float needle when the float moves up and down. You can bend that slightly if your float level needs adjusting, but unless it somehow got out of adjustment, then it's probably set O.K. and better to leave it alone. That motor was made by Tanaka out of Japan, maybe check their web site for manual and parts. I've had a Gamefisher/Tanaka for over 25 years and they're dead simple, easy to work on, dependable. Good Luck!
