trendsetter240
- Jun 22, 2009
- 1,458
I have a 1 3/4 inch hole in my transom that I'm trying to repair. The previous owner had a drain plug epoxyed into the hole and I'm looking for a more permanent solution.
I was thinking to use a hole saw and cut out a 1 3/4 inch plug of marine grade plywood, coat it with 3m 4200 and tap it into the hole. Would this be a reasonable repair? Does a hole of this size comprimize the integrity of the transom?
I've attached a pic of the hole after I cut out the rubber plug.
Cheers
Cheers
