When I bought the boat it had a blown head gasket on the right side replace the head gasket clean carburetors new plugs fired right up seems to be running okay at home that felt like it was a little sluggish on the water pull the plugs out and they all look fine except for one which still look brand new
What I thought....
That tells you only that when you remove the plug and lean it against the block that the spark jumps about a 1/32" gap.
You need to make sure that it will jump a 3/8" gap in an open-air spark tester.
