bigblock454
- Apr 28, 2008
- 206
Well, my buddy (who is a I/O guru), informed me that my drive ratio is a 1:65:1, This is to go behind a 5.7 mercuiser in my 1993 Bayliner "Classic" 2452 that was originally equipped with a 5.0. He is recommending a gear ratio change for the ability to deal with the increased torque of the 5.7. He is going through the drive right now, to determine it's overall condition. He says "it appears that water as made it's way in there at some point, because he can see a little surface rust on the gears, but all feels good turning" as stated, he is in the process of going through it. He is also going to figure out what it will cost to swap the ratio over to a 1:47:1, to determine the best "course of action". Although entirely possible to run the current 1:65:1 behind the 5.7, he mentions that it will be a rough life for it. so the options are: go through my current drive I have with 1:65:1 ratio, replacing whatever internals it needs and run it as is... or rebuild and re-gear current drive with whatever internals it needs PLUS new 1:47:1 gear set... purchase a used "merc" 1:47:1... or purchase a brand new SEI 1:47:1 unit and just "plug it right in". If I hadn't read (a few) negative reviews, I would have already purchased the SEI drive, but I admit, I'm a little hesitant because of those reviews. I will be guided mostly by what my buddy recommends (who has installed SEI's in a lot of his customers boats with great success), but love to hear from others as well, to get a more broad potpourri of info from the experience here at iboats. I realize that I can prop the boat to obtain pretty much the performance expected from the 5.7, but also realize that the "bigger" the prop, the more stress on the "weaker" gears in the upper drive. What would YOU do? I've mentioned this in so many words in other posts of mine, but trying to get the best help by posting it in the appropriate place under it's own topic heading. Thanks guys.
Norm
Norm
