z00m
- Jul 9, 2014
- 21
Ok, so you might have seen my thread about leaking transoms and worn out props. The boat has had all of the engines, transoms and drives removed and everything that lived in the water looks in terrible shape. The only used parts I can find and look good enough to use are with the yard doing the work. Transoms and drives are from a trailer boat that had 170HP V6's in it.
I took the liberty of noting the serial number on one of the drives and it is a 1995 1.84 RH rotation drive. The ones on my boat were 1991 1.50 RH rotation. My question now is what to do about the drive ratio difference. One of the objectives was to fit 4 blade props. My 3 blades were 14.5" x 17P. If I fit 4 blade 14" x 20P Alpha 4's, will I be in a sensible rev range?
Not really sure what old WOT was as I never used it (new to me old boat) but when the bottom was clean I saw about 23 knots at 3100 RPM if that helps. Since there is a 19% difference in the drive ratio, does that equate to 19% difference in RPM for the same speed? (3100 + 19% = 3689?)
Using mercury's prop selector, for my type of application on a 5T boat they say a 14" x 20P Alpha 4 would be appropriate for a 1.81 drive (doesn't allow me to select 1.84) to achieve 43odd MPH at 4500RPM. This would be based on a 2000 model 5.0 carb engine at probably 260HP? My LX was 230HP when new so probably some ponies have escaped since then.
So the question to the experts - am I jiggered and should go to the expense of changing the gears or would it be ok to use the 1.84s with the 4 blades? Replacing everything has eaten a big hole in the budget (doing manifolds and risers while its apart) and this is an additional cost I can't really bare right now.
