jgbutler1956
- Aug 2, 2007
- 16
I've been working on my 1988 Johnson 140 hp trying to get it ready. Checked compression and have 90,90,72,90 on cylinders. Top right low one.
Took off head covers, cleaned carbon off pistons, put "ring free" in fuel new gaskets, and run engine, etc... when I checked cylinders, they looked good.. no scaring, clean, no grooves, pistons didn't have alot of play.. did all the above and only gained about 10lbs on low cylinder.. (went from 60 to 72) Any ideas? Can I run it like this? Are the rings stuck on this cylinder? I haven't cleaned the carbs....will that help? new to this. Thanks for any help
