I agree, the most likely thing is the coils are dragging on the magnets. A worn or incorrectly assembled armature plate will cause them to drag too.
Just so you know, the correct starting position is with the motor in neutral, turn the twist grip as far as it will go toward Fast. The shifter interlock will limit the throttle to the correct position. The "Start" word on the twist grip is seldom, if ever, correct. The mark on the cam will actually be a bit beyond the roller in the real start position.[/QUOTE]
I wish I'd read that 3 hours ago. I've taken my entire throttle assembly apart about 3 times trying to get the 'STOP' line on the twist grip to align with 'true stop'. My biggest concern was if the twist grip didn't align at 'Stop', I might not get full throttle (my carb is off right now, waiting for the rebuild kit.)
Oh well. It was good exercise anyway.
