10 sheets up!
marlboro180
Re: 10 sheets up!
Sweet! Nothing like 3/4 ply up a ladder! Looking good.
angus63
Re: 10 sheets up!
Ten? I only count eight! Back to work slacker!!!;):p
rbh
Re: 10 sheets up!
Bobby T-
Like Bart SR said, you are off setting the sheets arent you???? half sheet, then full sheets for the 1st row and the third and the fifth and so on. You need over lap for the sides of the sheets.
rob
Autotech
Re: 10 sheets up!
Dang:D ya'll are some slave drivers. I thought I was doing good just to get those suckers up. Angus 19 now. B Sr. let me get the first run down first then I'll start the half sheet on the 2nd run. Fourth lesson learned in construction Tongue and groove probably requires 2 people. Will post pictures later.
Bart Sr.
Re: 10 sheets up!
Sorry. No offense intended.
EDIT: If you were a couple of states closer I would come and help.
Autotech
Re: 10 sheets up!
None taken!
Now if I could just talk RBH to drive his digger derrick down here and put up my last 8 Poles. Since everything is frozen up there :D I don't think it should be a problem.
rbh
Re: 10 sheets up!
None taken!
You got the diesel buddy, I got the time. Even got a couple of spare boxes of cat 6 and some left over fiber, lets prewire this sucker. :D
rob
Autotech
Re: 10 sheets up!
Little farther today but Not a thing is square:confused:. Thats life;). Just gotta work around it. I hurt more than the first ski session in the summer:p.
Bass Man Bruce
Re: 10 sheets up!
Oh man! That is gonna hurt! :eek:You shoulda squared up the floor joists B4 the deck went down. Everything fits better when you are square and plumb.
Don't worry, it's all still do-able but you will have a little xtra work when you hang drywall.
Keep up the good work and good luck!:)
ps
I don't know your experience level so don't be insulted if I underestimate you, but when you need to square something measure length and width on each side so each is equal and then make sure the corner to corner (hypotenuse) distance is the same.
Or, 3-4-5 rule, 3 feet on one side, 4 feet on the other with a 5 foot diagonal.
kenmyfam
Re: 10 sheets up!
You are getting there !!! keep working at it. Looking forward to more photos as things progress.
